Philips BE-531-A
achica
Philips BE-531-A
Mensaje por achica »
Hola, ha caído en mis manos una philips be-531-a del año 1953. El estado es bastante chungo, tiene mierda del año que le pidas, el díal no se mueve, no la puedo enchufar (ni se me ocurriría) a 220v. Dejo fotos. En cuanto tenga tiempo, cosa difícil, iré desmontando y limpiando.
Si alguien tiene esquema o más información, se agradece.
[img]http://s6.postimage.org/47luqodh9/IMG_20150415_103110.jpg[/img] [img]http://s6.postimage.org/spdyekg1p/IMG_20150415_103142.jpg[/img] [img]http://s6.postimage.org/4zt43m725/IMG_20150415_103219.jpg[/img] [img]http://s6.postimage.org/mr4qi2mgt/IMG_20150415_103253.jpg[/img]
[img]http://s6.postimage.org/oba2gguv1/IMG_20150415_103526.jpg[/img] [img]http://s6.postimage.org/uq93d51kt/IMG_20150415_103606.jpg[/img] [img]http://s6.postimage.org/j2f1ilcfx/IMG_20150415_103626.jpg[/img] [img]http://s6.postimage.org/yp6avyq7x/IMG_20150415_103643.jpg[/img]
[img]http://s6.postimage.org/p5wm2i2pp/IMG_20150415_103651.jpg[/img] [img]http://s6.postimage.org/o3rhh2q7x/IMG_20150415_103951.jpg[/img] [img]http://s6.postimage.org/p7blt1av1/IMG_20150415_104227.jpg[/img] [img]http://s6.postimage.org/qnn4b6drx/IMG_20150415_104255.jpg[/img]
[img]http://s6.postimage.org/407v50y7x/IMG_20150415_104303.jpg[/img] [img]http://s6.postimage.org/hv65nhsn1/IMG_20150415_104309.jpg[/img] [img]http://s6.postimage.org/cl16w78e5/IMG_20150415_104321.jpg[/img] [img]http://s6.postimage.org/q3838hkjh/IMG_20150415_104330.jpg[/img]
[img]http://s6.postimage.org/5x4l9lovx/IMG_20150415_104337.jpg[/img] [img]http://s6.postimage.org/har4kszel/IMG_20150415_104433.jpg[/img] [img]http://s6.postimage.org/8h083pcfx/IMG_20150415_104811.jpg[/img] [img]http://s6.postimage.org/t2jl9cjel/IMG_20150415_104819.jpg[/img]
[img]http://s6.postimage.org/cg2109qgt/IMG_20150415_104828.jpg[/img]
EMT 948, Thorens TD 316 Mk II, TD 105, Basf 8120, Dual 1235, Kenwood KP3022F
Pioneer PD 6700, Pioneer SX 450, Pioneer CS 997, Phillips AH-494
Denon DRM-800A, Revox C270
esoj_luar
Mensaje por esoj_luar »
Pues quitando la capa de mugre que tiene, el resto se ve en buen estado (salvo los defectos estéticos en madera y ese botón roto...).
Interiormente tiene pinta de echar a cantar en cuanto le cambies los correspondientes condensadores electrolíticos y de papel que tiene. A no ser que alguna válvula esté fundida o que el trafo lo quemaran yo creo que canta seguro.
Paciencia, paso a paso, suerte y al toro, que seguro que la pones a cantar.
Salud.
Raúl.
esoj_luar
achica
Gracias Raul, a ver qué puedo hacer.
Fotolife
Mensaje por Fotolife »
Hacer ,hacer ,lo que me parece es que trabajar mucho,pero merece la pena.Suerte en esta aventura.
Koldopascual
Mensaje por Koldopascual »
Hola, Saludos a todos!
Soy Koldo de Barcelona, tengo ya 57 y una cierta nostalgia por todos los equipos antiguos, tanto equipos de audio como automóviles, ya no se fabrican esas líneas y con esos cromados..
Bueno, yo veo una Radio muy bonita! tiene hasta habitantes! A la vista utiliza válvulas de la serie Rimlock y junto a la rectificadora, la AZ-41 se lee 125, si quitas esa chapa, seguro que eso es un cambio de tensión y verás el 220. Se desenchufa y se vuelve a enchufar en la posición del 220 por la ventanita.
Luego muuuuucho de aspiradora, otra sesión de soplado y pincel junto a un bote de CRC de contactos, 2-26 por ejemplo, y CRC a los conmutadores, contactos, potenciómetros, y poleas del dial, ejes etc...
Y con todo limpio, y las partes correspondientes engrasadas, habiendo hecho el cambio a 220 en el cambio de tensión, yo la enchufaría, que seguro que te dice algo.
Si tose mucho, fuerte ruido de alterna, cuando sintonizas una emisora fuerte, a cambiar el condensador electrolítico de filtro de la parte de la alimentación, el bote de aluminio roscado al chasis que son dos, condensadores en uno. Truqillo! Yo a veces si no he podido encontrar el original, he cortado las patas y he puesto condensadores de los de ahora por debajo que al ser mucho más pequeños caben en el chasis y no se ven, conservando la estética del original que queda anulado.
Y así poco a poco ir viendo y diagnosticando los problemas.
Es una buena radio que cantaba muy bien, disfrutarás mucho cuando la tengas funcionando. Mucho ánimo y suerte!
esoj_luar
Bienvenido al foro, Koldo de Barcelona.
Por cierto, Koldo ¿es nombre vasco?. Así se les llama a los Luises en el Pais Vasco.
Salud.
Raúl.
Koldopascual
Gracias por la bienvenida chicos.
Sí Raúl, es nombre vasco, soy de Bilbao residente desde hace más de 35 años en Barcelona.
Koldo es diminutivo de Koldobika, y con e se hace el femenino Koldobike, Luisa.
Saludos Amigos!
achica
Philips BE-531-A
Koldopascual escribió:Bueno, yo veo una Radio muy bonita! tiene hasta habitantes! A la vista utiliza válvulas de la serie Rimlock y junto a la rectificadora, la AZ-41 se lee 125, si quitas esa chapa, seguro que eso es un cambio de tensión y verás el 220. Se desenchufa y se vuelve a enchufar en la posición del 220 por la ventanita.
Hola Koldo, bienvenido.
Los "habitantes" ya han sido desahuciados, me he comportado como un banco. El otro día tuve un rato y la limpié con aire, a cierta distancia, después separé el mueble de madera de la parte electrónica. Este modelo no tiene selector a 220, si no, ya la habría enchufado. La he llevado a casa de un amigo que tiene taller, yo no tengo, este amigo es un técnico con experiencia y entre los dos vamos a intentar arreglarla.
En principio tiene pinta de trafo quemado pero hay que mirarlo más despacio, tendré que buscar los botones ya que están todos para cambiar, también me he encontrado con que la tela está pegada a la madera con lo que la limpieza será más difícil. En fin, conforme vaya haciendo cosas os contaré. No he podido sacar fotos, pero las sacaré y las colgaré.
Estas radios primero se sanean y luego se enchufan. Hay que cambiarle todos esos condensadores de papel que se ven (los negros) antes de enchufarla y los electrolíticos también.
A continuación y si no se aprecia nada más estropeado ya se puede enchufar.
