Algunos de mis aparatos
Buenos dias,
Aprovecho para enseñaros una muestra de algunos aparatos de mi colección. Muchos de ellos llegaron a mi en un estado desastroso. Con paciencia y tiempo, he podido recuperarlos y dejarlos a su estado original.
Espero que os gusten.
ZONOPHONE, USA, 1905-1907
[img]http://s5.postimage.org/inobsuefr/zonophone_3.jpg[/img]
png image hosting
COLUMBIA EAGLE, USA, 1898-1900
[img]http://s5.postimage.org/b8z00gsk7/eagle_2.jpg[/img]
free image hosting
VICTOR MODELO "E", USA 1901-1904
[img]http://s5.postimage.org/snntmhf2v/VICTOR_E.jpg[/img]
hosting images
PATHE "OMNIBUS", Francia, 1908
[img]http://s5.postimage.org/a1pnlzrtj/omnibus1.jpg[/img]
image hosting jpeg
GRAMÓFONO ORPHEUS, Barcelona, ca 1915
[img]http://s5.postimage.org/e36qrnk47/ORPHEUS.jpg[/img]
image host
PATHEPHONE MODELO 17, Francia, 1913
[img]http://s5.postimage.org/yjhr9vudz/PATHE_17.jpg[/img]
image host
ZONOPHONE "PARLOR", USA, 1900-1901
[img]http://s5.postimage.org/xjrge6f87/ZOOPHONE_PARLOR.jpg[/img]
free image hosting
EDISON HOME, MODELO A, USA, 1903
[img]http://s5.postimage.org/xm6qn9thz/edisonhome.jpg[/img]
image host
COLUMBIA Q PRIMER MODELO, USA, CA 1900
[img]http://s5.postimage.org/dsumukg47/COLUMBIA_Q.jpg[/img]
image hosting
EXCELSIOR PHONOGRAPH, Alemania, ca 1900
[img]http://s5.postimage.org/y1mlu14t3/excelsior1.jpg[/img]
free image hosting
GRAMOFONO MONARCH JUNIOR, Francia, ca 1904
[img]http://s5.postimage.org/iip5wwwif/monarch_1.jpg[/img]
hosting images
VARIOS MODELOS PORTÁTILES (años 20), PUCK PHONOGRAPH (ca 1900), y caja de música SYMPHONION (ca 1890)
[img]http://s5.postimage.org/dnvgymy6v/PETITS.jpg[/img]
hosting images
CAJA DE MUSICA "IMPERIAL", Reino Unido, ca 1890
[img]http://s5.postimage.org/qa5vvh0nr/imperial_3.jpg[/img]
image host
Ya iré subiendo mas fotos.
Un saludo !!!
Albert.
png image hosting
free image hosting
hosting images
image hosting jpeg
image host
image host
free image hosting
image host
image hosting
free image hosting
hosting images
hosting images
image host
Un saludo !!!
Albert.
- arturo
- jotarama
[img]http://smilies-gifs.com/animo/21animo.gif[/img]
como dicen por cataluña "que no soy" la madre de deu....., pedazo colección, me he quedao pasmaoooooo.......
- jotarama
Y tanto. Algunas de esas bocinas (la del Victor modelo E, la del Pathe omnibus , la del Orpheus o la del Edison Home), son auténticas obras de arte.
Yo, en cambio, solo dispongo de este :
[img]http://i858.photobucket.com/albums/ab14 ... CF4896.jpg[/img]
[img]http://s9.postimage.org/g6w89np0r/19122011888.jpg[/img]
Hola a todos,
Muchas gracias por vuestros comentarios. Mi primer gramófono lo coseguí cuando tenía 13 años (hace ya 28), y, con tiempo y paciencia, he ido recopilando estos y otros aparatos que ya os iré enseñando (faltan algunos por fotografiar). Muchos de ellos estaban en un estado ruinoso, y siempre, al restaurarlos, procuro devolverles el aspecto original que tenían. Muchas veces ha sido un verdadero quebradero de cabeza, sobre todo, el tema de la restauración de las pintura de las bocinas. Muchos modelos, como el Pathé Omnibus, no tenían de origen una pintura propiamente dicha sobre la bocina. De hecho, era una laca teñida que iba aplicada directamente a la bocina. Obviamente, este material es muy delicado, y el 90 % de las bocinas originales con este acabado están en un estado penoso. Por suerte, pude copiar la técnica que empleaban los artesanos de aquella época y los resultados son geniales.
De más está deciros que cualquier duda/aclaración o lo que necesiteis, podeis consultarme sin ningún tipo de problema. Creo que es muy importante que en este espacio compartamos nuestros conocimientos.
Un saludo,
Albert.
Un saludo,
Albert.
- jotarama
Y tanto que son geniales. Qué técnica es esa, se puede compartir? Te lo digo porque me interesan las técnicas decorativas y nunca se sabe si puede uno luego aplicar algo con un acabado tan estupendo.azul28 escribió:Por suerte, pude copiar la técnica que empleaban los artesanos de aquella época y los resultados son geniales...
Gracias de antemano.
Hola de nuevo,
Voy a intentar resumiros, paso a paso, la técnica que utilizo para lacar las bocinas y que queden con el aspecto traslúcido, tal y como eran los acabados originales en muchos modelos.
1)- En primer lugar, es muy importante decapar completamente la bocina, y posteriormente, lijar el metal hasta que quede completamente liso y brillante. Lo que mejor resultado me ha dado, es la utilización de lijas de agua, de diferentes grosores (primero de grano mas grueso, para terminar con uno mas fino). Limpiar muy bien la superficie lijada, y dejar secar completamente.
2)- Posteriormente, dar el acabado de color que queramos. Hay que utilizar laca para pintar bombillas. Hay de diferentes colores. Incluso, se pueden mezclar para coseguir la tonalidad deseada. Para este proceso, utilizo la laca de bombillas diluida con disolvente que venden para esta finalidad. Para aplicar la laca, recomiendo utilizar cualquier aerógrafo o pistola para pintar maquetas (en INTERKITS venden un modelo muy barato, de ña casa VEGA, que da resultados excelentes). Dar pasadas muy finas. Ya vereis que se seca muy rápido. Posteriormente, es importante que limpieis muy bien la pistola. La laca se seca rapidísimo.
3)- Una vez dada la laca, es necesario fijarla, ya que sobre el metal, la adherencia no es muy buena. Cuando esté completamente seca, barnizar la bocina con un spray de barníz para metales. La técnica ha de ser la misma que para dar la laca. Pasadas muy finas, dejar secar e insistir de nuevo. Vigilar sobre todo que no os gotee el barniz sobre la bocina lacada. Es cuestión de práctica, pero insisto, no es en absoluto difícil.
4)- MUY IMPORTANTE. Dejar secar la bocina lacada y barnizada en un lugar sin polvo. Una vez seca, viene la parte de pintar las nervaduras y el borde dorado. Como todo, es cuestión de cuidado y paciencia. En mi caso, utilizo cinta adherente para marcar las nervaduras (pegarlo con mucho cuidado). Después, se da la pintura dorada (de base aceitosa, a ser posible), con pincel. De nuevo, pasadas muy finas e ir insistiendo (no cargueis con mucha pintura el pincel). Dejar secar (no totalmente), y retirar la cinta CON MUCHO CUIDADO.
En principio, esto es todo. De todas formas, cualquier duda o aclaración que necesiteis, ya lo sabeis. Preguntar lo que creais oportuno.
Un saludo,
Albert.
Un saludo,
Albert.
Hola Pillo69,
Pues no queda otro remedio que meter la mano y lijar así. Lijadoras mecánicas no funcionan igual (los acabados son mas irregulares, no llegas a aristas/bordes, etc...). De todas formas, tampoco es tan complicado. Es cuestión de paciencia.
Tema niquelados/cromados: Raramente el acabado era cromado (sobre todo en aparatos anteriores a 1925). Si el recubrimiento está en un estado aceptable, prefiero pulirlo con pasta para pulir metales, y después encerar. En caso que necesite ser cambiado, llevo las piezas a un taller en Barcelona dónde tienen infinidad de acabados. El 80 % de aparatos llevaban las piezas metálicas con un baño de níquel, aunque, el brillo se ha de matizar.
Un saludo,
Albert.
Un saludo,
Albert.
