GRAMÓFONO PORTATIL SUIZO PAILLARD - SWISS
Hola, antes de nada presentarme. Soy un chico de un pueblo de Sevilla, me encanta todo lo antiguo, no se porque pero veo algo de otra epoca y se me van los ojos... me atrae no lo puedo remediar. Me gustaria hacerme con un gramofono, ya que el otro dia compre en un rastro un album con 12 discos de pizarra y me gustaria oir esa melodia caracteristica de antaño.
Vi en online un gramófono portatil suizo marca paillard-swiss, que me pueden decir de el, año, calidad de sonido...no tengo ni idea de estos aparatos tan intigrantes. Gracias a todos y espero compartir experiencias con vosotros. Algunas fotos.
[img]http://s28.postimg.org/z5u5g9aw9/40745807.jpg[/img]
[img]http://s9.postimg.org/ahro9kbiz/40745807_17790459.jpg[/img]
[img]http://s14.postimg.org/voegog1gt/40745807_17790462.jpg[/img]
[img]http://s9.postimg.org/noh49378b/40745807_17790463.jpg[/img]
[img]http://s8.postimg.org/a0r98cn75/40745807_17790469.jpg[/img]
[img]http://s22.postimg.org/mzkvrqgy5/40745807_17790472.jpg[/img]
Rebuscando en Internet he encontrado alguna página sobre estos gramófonos suizos:
Jan.
http://www.portable-gramophone.com/pail ... mophone.ws
Paillard of Sainte-Croix, Switzerland, made music boxes from 1814, then cylinder phonographs from 1898. In 1904 they began making disc gramophones, and in 1910 brought out the Maestrofone, which ran on hot air. Paillard Bolex cameras are still available today, and their Hermes typewriters were made until the 1960s.
The soundbox on John Peel's black Paillard, with an aluminum diaphragm, displays "Maestrophonic S 18 / Fab. Suisse". No. 301 is stamped on the inside rim of the case, in front of the speed control. The folding crank doesn't detach, and the 9-inch turntable is capable of playing 10-inch records. It has a single spring, 3 1/2 feet x 3/4 or 7/8 inches wide, which plays one record safely. The speed control lever says "Presto" on the left side, "78" in the middle, and "Lento" on the right. After removing five screws, one can see serial number 2465865 on the plate at the bottom of the motor, inside the case. Also inside the case there is a circle with letters around the rim, stating "Fab. Suisse / Made in Switzerland / Paillard". Model "No. 175" is written at the bottom of the motor.
Paillard de Sainte-Croix , Suiza, fué en su origen un fabricante de cajas de música a partir de 1814 , a continuación, fonógrafos de cilindro en 1898. En 1904 comenzaron a hacer gramófonos de discos , y en 1910 sacaron a la Maestrofone , un modelo que tenía motor de aire caliente. Las cámaras de cine Bolex Paillard todavía están disponibles hoy en día, y sus máquinas de escribir Hermes se hicieron hasta 1960 .
La caja de resonancia es de color negro, diseñada por Paillard (John Peel), con diafragma de aluminio, muestra "Maestrophonic S 18 / Fab . Suisse" . la inscripción N º 301 se encuentra grabado en el borde interior de la caja , frente al control de velocidad. La manivela plegable no se separa, y el plato de 9 pulgadas es capaz de reproducir discos de 10 pulgadas. Cuenta con un solo muelle , 3 1/2 pies x 3/ 4 o 7/8 pulgadas de ancho , que es capaz de reproducir un disco entero de forma segura -es decir no hace falta dar más cuerda-. La palanca de control de velocidad tiene las indicaciones "Presto" en el lado izquierdo, "78" en el centro, y "Lento" a la derecha . Después de quitar cinco tornillos, uno puede ver el número de serie 2465865 en la placa en la parte inferior del motor, que está dentro de la caja. También dentro de la caja hay un círculo con las letras alrededor del borde , afirmando que "Fab. Suisse / hecho en Suiza / Paillard". Modelo "Nº 175" está escrito en la parte inferior del motor
[img]http://i1153.photobucket.com/albums/p505/Jan7MAP/U-Boote/POSTS/GramoacutefonoPaillardIsaac-400px.jpg[/img]
http://www.liveauctioneers.com/item/1018036
Portable Gramophone "Paillard" Made in Switzerland, mechanical or electrical drive, automatic stop function, serial no. 305. - Excellently and costly constructed, plays very well!
Gramófono portátil "Paillard" Hecho en Suiza, de accionamiento mecánico o eléctrico, función de parada automática, nº de serie. 305. - Estado de conservación, impecablemente construido, ¡funciona muy bien!
Jan.
Última edición por Jan7 el Mié Feb 12, 2014 5:03 pm, editado 2 veces en total.
Creo que lo mejor es hacer como siempre , probar antes de comprar Si nunca has tenido un aparato de ese tipo no te aventures a comprar a un desconocido a cientos de kilometros de distancia
En Sevilla tendras oportunidad de que algun anticuario o algun particular te enseñe algun gramofono y asi apreciaras su sonido y veras el funcionamiento A partir de tener unas nociones basicas lanzate a comprar si estas convencido
Un ultimo consejo , desconfia de las gangas nadie vende aparatos en buen estado con antiguedad por poco dinero
Hola de nuevo amigos, pues ya me llego el gramofono, a ver que opinion me dais de el. Os pongo varias fotos y un video funcionando. Que tipo de diafragma es ese? No encuentro informacion. Gracias.
[img]http://s30.postimg.org/7anfa03kd/DSCF2587.jpg[/img]
[img]http://s28.postimg.org/3ninddtdl/DSCF2588.jpg[/img]
[img]http://s27.postimg.org/ouj69rvfz/DSCF2592.jpg[/img]
[img]http://s7.postimg.org/3zi5c2hiv/DSCF2594.jpg[/img]
[img]http://s15.postimg.org/livv7s9hj/DSCF2590.jpg[/img]
[img]http://s10.postimg.org/t5u8f4hs5/DSCF2596.jpg[/img]
[img]http://s4.postimg.org/ihsn6oo5l/DSCF2598.jpg[/img]
[img]http://s11.postimg.org/mra3i85lr/DSCF2600.jpg[/img]
