DUDA: Previo PHONO BOX II de Project o PHONO RECORD USB
forbidden
Mensaje: # 16864Mensaje forbidden »
Estoy hecho un lío y justo ahora necesito vuestra ayud más que nunca, tengo que decidirme entre estos dos previos de phono:
previo PHONO BOX PROJECT: Input impedance, MM 47kohms/120pF Input impedance, MC 100ohms/120pF Gain, MM 40dB Output voltage typically 300mV/1kHz at 3mV/1kHz (MM input) Gain, MC 60dB Output voltage typically 300mV/1kHz at 0,3mV/1kHz (MC input) Max. output 9,5V (1kHz) Noise floor, MM 86dB (94dB - A weighted) Noise floor, MC 68dB (75dB - A weighted) THD, MM 0,01% THD, MC 0,05% RIAA-equalisation curve accuracy 20Hz - 20kHz / max. 0,5dB Outboard power supply 16V/200mA AC, suitable for your country's mains supply Power consumption 16V/30mA AC Dimension W x H x D 103 x 38 x 115mm Weight 570g without power supply
Y ESTE OTRO
PREVIO PHONO RECORD BOX USB: PROJECT RECORD BOX USB - Previo de phono con convertidor analógico/ digital. Salida USB MM Phono Pre-amplifier with A/D converter and USB output. Digitalisation of analog signals for recording direct to disk via USB with suitable recording programs • Runs on Windows®, MacOS® and Linux® operating systems • Metal case shields the electronics from vibrational and electromagnetic interference • Small size allows installation close to record player • Optimal channel separation through dual-mono circuitry • Special low-noise ICs used • Gold plated RCA connection sockets • Outboard powersupply included Input impedance 47kohms/100pF Gain 32dB Output voltage typically 200mV/1kHz at 5mV/1kHz Noise floor 82dB (88dB - A weighted) THD <0,05% RIAA-equalisation curve accuracy 20Hz - 20kHz / max. 0,5dB A/D converter 16-Bit Delta Sigma Sampling rate 48kHz USB-output digital serial data protocol USB 1.1 Operating systems Windows®, MacOS® and Linux® Outboard power supply 16V/200mA AC, suitable for your country's mains supply Power consumption 16V/100mA AC Dimension W x H x D 105 x 30 x 75mm Weight 350g without power supply
Teniendo en cuenta que a mi me da un poco igual que tenga o no USB porque no pretendo pasar vinilos a formato comprimido, cuál de ellos me daría mejores prestaciones en cuanto a sonido. Tengo un amplificadro JVC FX R10-S y mi giradiscos es un Project Debut III.
Mil gracias.
Mensaje: # 16866Mensaje -- »
el primero que describes
forbidden
Mensaje: # 16867Mensaje forbidden »
Gracias por tu rapida respuesta. Supongo que tu decisión está basada en un mejor sonido, verdad? Gracias de nuevo
Mensaje: # 16869Mensaje -- »
por supuesto el primero con diseño pensado directamente a hi-fi el segundo aunque tiene ese comcepto, va más encaminado para pasar vinilos a ordenador, no quiere decir que sean malos, simplemente tienen ese otro comcepto, totalmente válido también si en un futuro te quieres pasar algún vinilo al ordenador
